| I have a customer with 2 8120 combines. One is setup with an accuguide Pro600 262 NAVII system and the other is setup with a FM-750 NAVII system.
He's trying to run both systems at 0 degrees, but apparently the combines are a couple feet off from eachother causing swath skips/overlaps.
I know a JD system and Trimble system have a different 0 degrees, but running an Accuguide with Trimble should be the same datum as an Autopilot with Trimble.
Edited by Canucker 8/23/2016 19:43
