WC MN | Go to the "more" button or the three dots (...) > Setup Builder > Create New File > Select Harvest including Variety Locator > Select your varieties (if they are not in there you will have to add them) > Select equipment you want to be saved to the display (same as varieties if they are not in there you will have to add) > Select Fields > give it a profile name and select display type to save to > save file.
Next hit the three dots button again (...) > MyFiles > select the file you created > then either hit the download button to use the data manger to get file on usb or 2600 card. Import new data into display.
One thing if you add equipment from MYJD the machines wont have any offset preset so you will either have to edit the offsets in MYJD or edit them once the data is in the display. | |
