| 2 years ago we got ours out and folded them out fine. When we folded in they went half way and stopped. Ours ended up being mice chewed wires right at the switch. It was a quick and easy fix. Probably not your likely culprit but is an easy check by taking out one of the switch blanks and looking down in there or the console comes out pretty easily by removing the nut under the cebis display. IIRC after you take the nut off you raise the console up at the front and when it clears the stud, you slide it back a little bit. | |
