Posted 8/5/2016 07:00 (#5451783 - in reply to #5451311) Subject: RE: PVC/Y drop question
Flat Rock Indiana
Why not look at using a heavy duty type of rubber hose connected to some metal hose and do that a couple time down the length you want then put a y on it. This would give you some flex plus give some weight. I wouldn't use a lot of metal. Just enough to get some stiffness and weight
