Central Wisconsin | I wanted to do this on our 1660 because we had the monitor in our 275. Ended up putting in a used agleader set with a ym2000, which you could upgrade to a 3000 monitor since the wiring is the same. Only cost me $600 for compete setup and worked perfectly. Once you get your calibrations in, it was within a few bushel on a semi load. 1660 is not a can system and that is why most newer yield monitor setups do not work well with those machines. We have a agleader insight on our 2377 and that is perfect also. | |
