Posted 7/25/2016 21:08 (#5432393 - in reply to #5432367) Subject: RE: JD 9650STS Oil going from Main Gear Case to Hyd Tank
Sw Minnesota
Had the same thing on my 9400 I believe. IF I can remember correctly, the main gear case and hydraulic tank are seperate but can run together because they share either a pump or a seal goes bad that allows the oil to run from one to another. My tech figured it out and I'm sure someone on here can help. Too long ago for me to remember
