Rosemont ON | New to us last fall, 5000 hrs on the engine, gear drive water pump, don't know the complete history on it. Got the rad out to get a pin hole fixed, should I be changing the water pump, I've read about different gear driven water pump problems so want to catch a problem before a bigger problem but everyone around here says not to worry about it. What say you? We only cover about 200ac a year if that makes any difference. TIA | |
