CDN | The 30 series uses similar components across all models except the larger 9530 (475hp) and 9630 (530hp) have larger engine oil capacity and heavier double reduction axles. The 24 spd has only been offered upto 460hp in the r series. So 475 would be comfortable. Changing to larger tires and adding enough ballast are the expensive parts. Probably be money and/or time ahead by trading to the right tractor in the first place, but it's doable.
Just note that pto is unavailable on the larger 9530-9630 wheeled versions. | |
