Posted 7/24/2016 16:52 (#5429978 - in reply to #5429680) Subject: RE: pull-type sprayer with hydraulic pump
Do not damage your hydraulic system trying to run a hydraulic motor the tractor was NEVER designed for. Hydraulic driven sprayer pumps were first used some time in the middle 60's. Your tractor does not have a cooler and reservoir capacity for a long term usage of that hydraulic load. A PTO driven pump will be the best solution for long term use.
