Posted 7/24/2016 10:44 (#5429338 - in reply to #5429247) Subject: RE: 8640 JD and Dozer blade ?
Cartwright, McKenzie County, North Dakota, USA
They make a good pair. Degelman/Deere dozer? Used one to push silage I like the Quad Range for that job. Before that used a 7020 with 12' dozer, worked well but hard on the clutch foot.
Look under the tractor if you are buying it. That will tell you whether to buy or run. Leaks every where, run!
