| I had this apart a couple years ago to put the pin back in it.I have it apart agin because its not going all the way into park. It seems like there is an adjustment nut on the top of the case turning a bolt inside of a spring which allows the the dog to go down into the gear and "park " the tractor. It is adjusted all the way down and still isn't fully in the gears. Seems like it won't hold if we put it together like this. Any ideas ? It is on the gear shifter in the cab. It works just not fully? | |
