Posted 7/23/2016 20:03 (#5428248 - in reply to #5428098) Subject: RE: Troubleshooting metalert lll sensor.
standahl - 7/23/2016 17:39
Just had the same issue. Rock made a small dent in bottom feed roll and did damage to the magnet. $3000 gets you a little over half way fixed. Good luck.
Hi standahl.
I'm being quoted about $3k CAD for #47508039R which is a reman sensor kit. I'm confused about where it should be twice that much? Did you replace the feed roll or the circuit board too?
