Posted 7/21/2016 20:28 (#5424296 - in reply to #5423779) Subject: RE: Perkins 4.236 timing - looks good - rats
nw pa
If it has the steel fuel lines with the rubber compression grommets,check to make sure that when someone installed the lines they didn't break off a chunk of rubber. Had fits with a 1155 that had a small piece of rubber stuck in the fuel ;pump.check the sscreen on bottom of fuel tank if in a tractor. on the bigger ones the drain plug has a built in screen for suction line.
