Appomattox/Fredericksburg, VA | The 2600 will have Greenstar basics on it so you'll have Harvest Doc. You'll need to set up your client/farm/field, make sure your task is defined as harvest and the correct crop year is selected (resources tab in GS2), and setup your documentation tab under the GS2 softkey. You might need to go into the Original Greenstar tab under setup and setup your header type and size. Can't remember if that is needed in the 60 series or not.
As far as displaying the information, you'll have to configure your run screen the way you want to show it. You can split screen to show the map and totals. That's up to you.
Edited by Glenn Dye 7/21/2016 08:29
