Posted 7/21/2016 07:13 (#5422954 - in reply to #5422858) Subject: RE: TS 110 with 16 x 16 transmission
New Brunswick, Canada
Replacing the bad seal in the clutch pack. You will be able to tell which one it is using the shop manual because the even gears are affected.
What is happening is there is so much leakage it doesn't build enough pressure in the transmission circuit to turn the light out. Eventually it will slip.
