Search Forums | Classifieds (33) | Skins | Language
PRO 700 Multi Swath Lines
WtvlPres
Posted 7/20/2016 06:02 (#5421093)
Subject: PRO 700 Multi Swath Lines
South Africa
Hi Guys
I am trying to export multi swath lines from Farmworks to a Pro 700 display. I exported it last season to a FMX display and it worked very nice. when you have a field with more than one AB line, the FMX would automatically select the correct AB line to use. I would like to see the same thing on the Pro 700, but we can't get that going.
On the Pro 700 I can see all the original AB lines, but it will not select the correct line, although I selected the multi line in the swath select box. It will select one of the lines and thats it, not changing at all according to your position in the field.
is there something I need to set up on the Pro 700 or what can I do to get this working. The Pro 700 is on V28.1 on a Steiger 550, and Farmworks is on V16.2.
Regards
