South Central Wisconsin | So the cable connects to the scv valve with a collar and jam nut on the bottom of the scv. The spool is directly below the knotter you turn to change the valvery from loader to motor to detent settings. Do not take the knotter off, can screw it up bad.
Spin the jam nut off, then the collar, and you should be able to see the end of the cable. 24 and 27mm wrenches for best fit, crescent wrench if you feel adventurous. | |
