Posted 7/18/2016 16:31 (#5418159 - in reply to #5417759) Subject: RE: Apex- getting new field to show in map tree?
Eastern Nebraska
Rob made a good suggestion. Also, move the data to the new field then I suggest in the filter to check all in each drop down, then uncheck them, click in the area where a map would be. This will make sure that there is nothing checked in the filters. Then you back and put a check mark in all for each drop down again.
