Thought we had a board problem , but now not sure . The red light that normally blinks on a Zareba is on , but steady , no pulse . Their customer service gal said if the light was on the battery was good and needed a board . We had a line on the ground a while before I found it and a prior post I read talked about a solar charger trying to charge a ground could burn a board . I have pulled the front off and see no obvious signs , but don't know what to test . The battery only has 4.19v instead of 6 . over 90 degrees and not a cloud in the sky for two weeks . The charger is 3 years old so a battery is not out of the question , but hate to spend money on one to find out I have a different problem . Anyone have any suggestions ? Thank you | |
