Central Ontario | I have a 2005 planter that I have used with a UD+ for years.This year I updated tractors and am using a Pro 700.It needed a firmware upgrade to get it working but has been working quite well except when planting the outside pass of a field.Usually I get half or 2/3 of the way around a field and it will stop metering like the section control shut it off for a short distance, sometimes a hundred feet then starts again on its own.I have tried turning off the overlap control and it doesn't seem to make a difference.The map shows the unseeded area and when I go over the spots it missed I can plant them the second time no problem.Usually when I start a field I have my guidence system on field mode and am recording a boundry.I am using planter wheel speed for a speed source.
