| You will end up with a larger hole in the interior piece than what is probably stock in a tractor with a buddy seat from the factory but it is only visible from behind the seat. It's been a while since i did mind but i believe that you need to drill a couple holes for a base plate and for the seat belt. The seat from deere came with good instructions and templates to help lay everything out. Only a couple hour job. | |
