Posted 5/12/2016 07:49 (#5296756 - in reply to #5296690) Subject: RE: How to tell if thermostat went bad in tw 10
South Western Ontario, Canada
If the rad is actually clean (put a light behind it and look through) then yes start with the thermostats and then if that doesn't cure it I would replace the water pump. Both are easy to replace.
