Near-north Ontario, French River | It's entirely up to you , get what you want, but do you really need a 700 class machine? I've got a 550 Grizz that will do everything I want and its been bullet proof., The reason I ask about the need for a 700 is because even with my 550 I run out of traction ( keep in mind I'm almost 300 lbs ! so ballast isn't an issue) long before I run out of power. What ever you decide, get a winch as well, if you sink a 700 you aren't getting it out without a winch if you are alone. |
