Posted 5/5/2016 20:50 (#5284790 - in reply to #5284630) Subject: RE: JD 7000 planter
Should be a hose clamp and a ring you can remove from the front side of the master cylinder under the center of the planter. Take it off, raise the planter all the way and hold your Hyd lever for a few seconds then repeat, that will rephase the Hyd. Then put the ring and clamp back on.
