Nectar Alabama | I spread fertilize all day with the tractor parked it when i finished. Went to get in it the next morning and it will just turn over but will not crank. I checked all the fuses but none was blown put new filters on didn't help. The lift pump on the frame real is running and when the filter is off is pumping fuel out of the filter housing but maybe not enough. Should the pump quit or at least change sound once it gets the system full because it never really changes. Sounds the same the whole time. Did crack the injector lines and just a very little bit of fuel is coming out of them. Sorry for long post but just wondering what to do. Thank yall. | |
