roaming | grampak - 4/30/2016 07:18
Looking for a way to turn on the work control on or off from a implement switch. Have a 2011 steiger quad and using a bourgault 5710 air drill. I cant use the EHR1 function because i adjust the implement up and down some as i am seeding. So every time i change my depth a little it trips the work control on or off. I can come up with different type of work switches on the implement, but do not know how in connect it to the pro 700. Is it possible thru thru the iso?
Assuming you're running the Large Tractor software in your Pro 700, you can hook up a normal 2-position whisker switch to the 2-pin Work Switch connector that is located in your fuse & relay panel. It should be labeled "Imp Switch". |
