NE Iowa | cable 4002304 is the one you should use. You could use either one but this one will plug directly into the display harness without a null modem cable and it will power the globe when the display is powered on.
If their are no NEMA messages turned on right now the integra will not recognize the receiver. Beings it's an A220 and not a 320 I don't think the integra will recognize it and allow you to configure it from the display. You need need to use an outback monitor or laptop to configure the nema messages.
Edited by TS79 4/30/2016 18:40
