Posted 3/16/2016 21:01 (#5180861 - in reply to #5180843) Subject: RE: fuller 13 speed troubles
Dearfield Co.
dont forget to change the pocket bearings as well-----------No one used to do it but now with the cheap bearings its almost required
should also add you need to make sure all your transmissions are the same before you try and swap back sections--------lots of different 13 spds out there
