Red River Valley | and those that are following along with that info.
these are questions I have no idea of the answer's and I'm trying to use the info you have brought forth
1) How do you foresee using this info into your marketing IE will you hold longer for sales, sell in smaller lots, Not sell anything until after harvest?
2) are you more likely to buy calls before planting ?
3) what is the make or break time frame on whether or not you see this weather event happening ?
4) If you see that temps are slightly warmer than normal in April and May will you hold longer on sales ?
5) If temps are warmer but the market does not react as much as you hope will you hold out until it comes to the realization of what your info proves ?
6) If the market reacts early to your Info will you start sales earlier than usual ?
7) what are some upside objectives you feel can be reached if we have a 2011 type weather year | |
