Posted 3/13/2016 07:34 (#5172737 - in reply to #5170910) Subject: RE: JD 980 Field Cult.
deereonly1 - 3/12/2016 07:15
X2....The OP is talking about the original standard duty springs. The heavy spring version, doesnt have a bolt through the spring and they supply you withe the tool.
I'm sure you are correct, I can visualize the other style and the problem of the metal straps not holding the nut.
