| If you have checked the solenoid and it is good, it will be the pressure switch, the pressure switch circuit, the solenoid circuit, or an internal leak in the transmission. Keep in mind while troubleshooting that the power shift valves are not stacked in order. From top to bottom they are in order 3,1,2,4. There are also test ports on the valve you can hook a gauge into to be sure the issue is not an internal leak. | |
