Wisconsin | mocofarmer7 - 3/9/2016 10:53
The 8225R has bigger/nicer cab. With the R's you have a "fancier" command center and can control your hydraulic flow rates/detent both ways.
In the end very similar tractors with essentially same chassis and motor(both tier 3). If I were deciding b/t the 2 I would first take into consideration the condition and options on each machine. If the 2 were very similar I'd go with the R.
^^^I'd agree. If both tractors are the same, I'll take the R's cab. Just put our 8230 up for sale because we replaced it with an R. |
