| We have one. For what we use it for it works great. Ours holds about 650 max unless it's real heavy corn. Traps work good and can dump in 30-45 seconds wide open. Get new rims and truck tires if that hasn't been updated. If you are updating that, make sure rims are true. Ours are not and causes it to hop pretty bad at certain speeds. Breaks haven't worked on ours for as long as I can remember. You'll want plenty of tractor on it and don't park it in a wet spot in the field. For our use, I would get rid of all our other wagons and take 4-5 more of these if they still made them but we have all drive over dumps, one being a 600ish bushel pit. been fairly low maintenance but doesn't see much use since we have gotten some newer brents | |
