Central Nebraska | PJB - 3/8/2016 18:52 It's hard to tell from the picture, but could the overflow pipe have a hole worn in it if it rubs on the seam of the radiator? Paul
I spent some more time investigating it and its definitely leaking at the seam. I'm not sure if someone has tried to fix it before or if there is just buildup and possibly solder on the seam. Its a hard area to clean but I might find a small wire brush and try to brighten it up some and put some JB weld on it. |
