Posted 3/7/2016 19:33 (#5161918 - in reply to #5161853) Subject: RE: Building a hydraulic power unit revisited
Sac & Story county IA
You should put a relief valve after the pump. In case the disconnect comes apart or doesn't get connected. You don't need a spool valve. The bypass solenoid will be adequate to start and stop motor.
