It's been a lot of years ago but here is what I got through JD It's got a parts country sticker on the box and the number SW05500 MK II Bead Cheata Edit quick web search turned up these 2 links One was listed under Farmex which is really Speeco who makes 3 point parts, pins etc. http://www.speeco.com/products.aspx?id=45&id2=353 The other is this place which I know nothing about. http://www.kramp.com/shop-es/en/717540/628770/0/Bead+Cheata+%28Bead+Breaker%29 Most likely all the same mine says made in China but does a good job for my use. Your not supposed to use an impact gun to run the threaded screw which pushes the foot down. Hand socket only ! Edit 2 Running the "where to buy" on the Speeco page turns up Tractor Supply as sources to buy. They can probably order out of their Speeco catalog. Just got a 10% off coupon off entire purchase at TSC 2/24-3/06 in the mail. Not sure if that would apply to special orders or not.
Good luck !
(0222061314a.jpg)
(0222061314d.jpg)
(0222061314c.jpg)
(0222061315.jpg)
Attachments ---------------- 0222061314a.jpg (56KB - 430 downloads) 0222061314d.jpg (137KB - 412 downloads) 0222061314c.jpg (137KB - 424 downloads) 0222061315.jpg (254KB - 466 downloads)
