NE CO | If speed is all you're after there is an output wire on the receiver that does just that. Depending on what tractor you have, in some cases this wire is ran into the Greenstar harness and sometimes it's not, but you're looking for the 211 wire that is in pin 1 on the receiver connector. This is an emulated radar speed signal that works with older components that just require a radar speed. If you run this wire into the cab and into your controllers it should do the trick. | |
