Does the Force Unlimited offer a "walking tandem"? It seems that if row-crop work is not a consideration, that the walking tandem would allow a lower box height, wouldn't it? The box looks fairly tall in the videos...same height @ the top of a JD cab? Anyone using the track model? Are they Land-Luvr tracks? Also, is that a New Leader box? If so, do you find the motors being mounted UNDER the pans a problem? I believe Chandler & BBI drive from above. Not sure which is better, but I've been told by some New Leader guys to "keep a spare motor around" due to their seals going out. No? |
