Washington Co Ks | What is the hyd fluid like? Is it cold there? I had two 706s and a 766 that acted in a similar way in the winter. When I changed the filter I found that it was coated with an icy sludge like substance. The filter was plugged. The new one did the same thing after a short time. I used Hy-Tran and it seemed to keep the water that formed in the transmission and rear end in suspension and when it flowed through the filter if froze on the surface. | |
