Reading Mn | I use annual ryegrass for cover crop at 8lbs acre,some use 4 lbs so there is less competition with the new seeding.Mix any other grass seed with it in the large box on the drill and run the alfalfa seed threw the small seed box.
With oats you will get 1 cutting of oats,with ryegrass it will come back every cutting.The annual ryegrass winter kills here so it doesn't come back the next yr. | |
