Search Forums | Classifieds (227) | Skins | Language
Homemade Direct Inject
JHEnt
Posted 11/25/2015 08:24 (#4918492 - in reply to #4918415)
Subject: RE: Homemade Direct Inject
Southern Illinois
You would need some way to measure the flow down to ounces. Smallest flowmeter commercially available measures only down to about .3 gal / min. That's why Raven used a piston pump that they could compute exact displacement from.
If you go through parts you can buy the Raven sidekick pump and old motor. You just can't buy them as an assembly. Then you can use the normal AL direct command to run it.
Edited by JHEnt 11/25/2015 08:27
