Eastern Iowa | When you download it from MyJohnDeere it will be a zip file, make sure you "unzip" to a USB. I'm assuming this data came from a JD 2630? If so, when you "open" the unzipped 2630 folder, drill down to the EIC folder, it will have a folder named Documentation, in that folder you will,need to make sure there is a GLOBAL.VER file. If not, copy and paste file, That file can be sourced from previous download that you may have on hand. Then SMS Should recognize. | |
