Search Forums | Classifieds (24) | Skins | Language
Pivot pins on 4 wheel drive
playing_in_the_dirt
Posted 8/14/2006 08:23 (#35607 - in reply to #35517)
Subject: Re: Pivot pins on 4 wheel drive
Monroe, OR
Yes M, you can replace them. I did my 850 and 800 Versatiles 20 years ago, you will need a 600lb ft torque wrench and a 4-1 torque multiplier. At least the lower pin is torqued to 2400lb ft. Block the tractor well, I am lucky enough to live near a sawmill that does large timbers, and found some 24"x24" blocks 4' long.
Parts will have them much cheaper than you can get them built, the pins are carburized.
