Montana | MY Honda engine on my Ag Truck spray Truck is burning oil and is kind hard to turn over to start with electric starter. Runs good when it is started and running. I have been using Chevron 10-30 oil
I checked compression then put oil in the cylinders and tested again , went from 140 Dry to !50 with oil so I am thinking not a big problem with rings.
Could valve adjustment help it gets pretty hot when spraying out a thousand gallon load. | |
