East Central Ia | softtail - 8/27/2015 19:35
If the combine is new enough, (not sure on what models) you could just have a bridge module talking to the cat system instead. when you go to set up the monitor and pick your model combine there maybe 2 different types of systems to pick from. Try the other one. if its talking to the cat system you basically are just reading that and will do the calibrating on the cat side
This is just on the 700 series so he should have a full Ag Leader kit in his machine.
I would assume the Impact plate in the top of the clean grain elevator is what the monitor is not finding? |
