Diamond Ohio | Case is 2014 machine , Case is using pro700 has 320/80r42,reg tires 20/30 spacing on booms Ro gator 2015 machine using ravens 380/80r 42 sprayer tires ,15 spacingon booms Rest options are same for each ,Guess im asking is the Rogator worth $8500,00 more then the Case .The case dealer has only sold 1 unit where Rpgator has multiple units out.Both dealers are same distance away.Also Case now calls their machine a 2250 with 4 speed hydro so did not know if that was issue.Is not seeing your wheels a problem we have narrower roads.
Edited by VERSATILE GUY 8/14/2015 19:52
