Stoddard Co. SEMO | One of my landlords is having problems with his 3020's clutch. He told me when he was going to start the tractor, he pushed in on the clutch, moved the shifter to a forward gear and it immediately started moving even with the clutch depressed. He told me that he removed the bottom plate off the transmission and said when the clutch was depressed, the throw out bearing only moved about 1/2". He told me beforetoday the tractor never showed any signs of malfunction. What might be his problem? | |
