Minnesota | Software could be an issue. I have seen a new software set solve many problems. Also, I have seen problems when data cards get full or if you get a corrupt file on the card. backing up the data on the card and then deleting it could be an easy thing to do to test if that is the problem. The speaker you speak of (lol), in an 8010 combine is actually located under the cubby in the armrest and is not in the display. I have had customers complain about the speaker volume not working and it has been because the speaker is glued to the side of the armrest. If it gets loose and falls down it tends to not be as loud, and a simple fix is to reposition it to where it started at, and away we go... | |
