Posted 7/29/2015 06:40 (#4705525 - in reply to #4704598) Subject: RE: Calibrated the Pro600 but the yield map didn't change.
On the pro 600 the uncalibrated map on the screen will not change if you calibrate it. Although if you apply the calibration like torn has said and you go to print the yield map it will be correct.
