Central Ill-Tremont | Have had very good luck with amine 24d . I believe was at least 2% . Can spray right up to beans as long as either there is no wind or the wind is blowing away from beans. Should be able to do two sides of bean field regardless which way the wind is blowing. Have sprayed a 50' waterway that split a bean field, with a 26' tractor sprayer , when there was no wind and had no trouble on beans. | |
